Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
2000 5.3 help
Old Apr 26, 2009 | 07:41 AM
s10hugger's Avatar
Default 2000 5.3 help
I just picked up my 5.3 and 4l60e trans today for my 1995 s10. I had to unbolt the trans and while turning the fly to unbolt the torque convetor and the motor turned very easy. Once I had the motor free I could turn the fly wheel by hand. Is this normal?
I paid 1500 for the motor, trans, s&p headers Speartch stand alone harness, speartech reprogrammed computer, and a couple boxes of misc fittings. All the parts are brand new with receipts never wiried up or bolted on.
Anybody looking for a Speartech stand alone harness?
Old Apr 26, 2009 | 08:16 AM
00ChevyScott's Avatar
Wearin' da big hat
Are there spark plugs in it?
Old Apr 26, 2009 | 08:38 PM
s10hugger's Avatar
Yes all the plugs are in it, there is oil in the pan, and the motor is suppose to have 50,000 miles on it.
Old Apr 28, 2009 | 02:44 PM
bowtieguy79's Avatar
Wow man... That doesn't sound good. rig up the starter and do a compression test on the engine stand.
Old Apr 28, 2009 | 02:46 PM
Wearin' da big hat
How does the valvetrain look? Could have a bunch of bent valves or all the valve seals are shot and are leaking compression. Or the rings are toast.
Old Apr 28, 2009 | 02:59 PM
ya and could have holes in the pistons from to much juice too.. Diagnose it before you tear it down.
Old Apr 28, 2009 | 03:03 PM
Wearin' da big hat
It'd only be 1 or 2 pistons if it was nitrous. He would still have compression in the other 6-7 cylinders. If it was nitrous, I'd think the rings are what would be gone, which would explain why none of the cylinders have compression.
Old Apr 28, 2009 | 06:48 PM
I was just farting in the wind and saying it could be a number of things. Agree'd could be the rings
Old Apr 28, 2009 | 06:57 PM
Mangled03gmc's Avatar
Baltimore Whore
Like stated do a comp check on it. you def shouldn't be able to turn it over by hand(that easy))
Old Apr 28, 2009 | 09:24 PM
s10hugger's Avatar
I will do one over the weekend if not sooner depending on work. I was told that the motor sat for about four years untouched still bolted to the trans.
