Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
1995 s10 5.3 conversion
Old Mar 20, 2009 | 08:53 PM
s10hugger's Avatar
Default 1995 s10 5.3 conversion
I have a 1995 s10 with a 350 tbi 5sp and I am going to put a 98 ext cab 3rd door on my frame and change it over to run a 5.3 auto. I am told that the wiring on the 98 cab will work with the 5.3 engine and trans.
I want to put a console shifter and I am not sure how to wire it in so that it all works.
Any help will be welcomed.
Thank you.
Old Mar 31, 2009 | 10:24 PM
silveradol33's Avatar
Not to be a dick man, but if you are asking questions like this you arent ready for a swap. The 98 harness will not work with the 5.3 and the console shifter should be the least of ur worries. There is a lot of info on here use the search and try and figure it all out! Good luck man!
Old Apr 2, 2009 | 09:54 PM
s10hugger's Avatar
The reason I ask is because there are so many people saying many different things. I put a v8 in my 95 and while doing so I found out I bought a truck that they only made the computer system for three years.
Now I am tearing down and starting over. Its no fun having a truck that wont go over 85 no matter what gear your in.
You have no idea all the b.s. I have gone through with the truck the way it is.
I just want to cross all my t's and dot my i's before I start this project.
The reason I ask about the electronics on the console is that I have a 2000 s10 v6 auto and I want to put a console sift in it. I just want to find out what do to with the shift lock on the shifter.
Thanks for the tip on my 95.
Old Apr 7, 2009 | 06:05 PM
Slimsilverado's Avatar
Do it man 5.3 makes great power
Old Apr 15, 2009 | 10:26 PM
s10hugger's Avatar
I have the cab corners welded in and I'm going to start on replacing the rocker panels this weekend. I am alot farther on my change out than I thought. I want to take my truck to the drag strip berfore I pull my 350 5sp and see what kind of numbers I get this year.
Old Jun 11, 2009 | 06:35 PM
5.3LJimmy's Avatar
10 Second Club
Just break it. All it needs is a ground and a signal from the brake light switch, but it's alot easier to ditch it.
Old Jun 21, 2009 | 08:01 PM
s10hugger's Avatar
I put the console in weeks ago and all went well. I found a wire comming from the break light the had power when I had my foot on the pedal.
Thanks for the tip.
mikeyjm1
17
Oct 29, 2015 11:04 PM
custm2500
Sep 8, 2015 05:53 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
wcrum17841
Aug 24, 2015 08:30 AM
Go5.3tt06
Jul 20, 2015 08:00 PM
