zo6 cam
Old Jul 29, 2006 | 11:33 AM
rk rumbler's Avatar
Default zo6 cam
i am needing some info on an 02 zo6 cam that i am thinking about putting in my truck cause i have a straight pipe exhaust with bullets and pacesetter lt's ,and a brute force intake and i need to get some more power and sound so if any body has any specs or sounds clips please help me out
Old Jul 29, 2006 | 11:55 AM
willyfastz's Avatar
Restricted User
.551"/.555" 218/204 117.5 '02 ZO6
I can hook you up with a Lunati that should out perform that cam unless your getting a good deal on that one.
Old Jul 30, 2006 | 01:35 AM
it isnt a reverse split, its 204/218
Old Jul 30, 2006 | 09:24 AM
willyfastz's Avatar
Restricted User
well here's the specs I have
'01 duration 211/204
'02 """ 218/204
'03 '''''' 218/204
Here's the duration on the LQ4
'00 190/191
'01 207/196 and so on
Old Jul 30, 2006 | 09:28 AM
Specifications
SDPC Part Number: 12565308
Manufacturer: GM Factory Replacement Parts
Advertised Duration Int. : 270
Advertised Duration Exh. : 282
Camshaft Duration @ 0.050" I/E : 204/218
Camshaft Lift I/E : 0.551"/0.541"
Lobe Seperation Angle : 117.5
RPM Range : 2000 - 6200
Camshaft Type : Hydraulic Roller
says SDPC2000.com
Old Jul 30, 2006 | 11:31 AM
ktmrider's Avatar
The specs S2BS posted are what I have via here http://www.smokemup.com/tech/ls1.php and my LS1/LS6 rebuild manual.
You are going to lose some low end but it should fly above 3500rpm. The 01 Z06 cam will retain more low end, you can swap in some 1.8 ratio rocker arms to compensate for the lower lift.
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
