z06 cam questions...
Old Nov 7, 2008 | 11:07 AM
pewter00's Avatar
Default z06 cam questions...
I did a search and yielded a million results for just threads that said cam so i figure i'll ask here since its just a quick question...
what kind of sound could i expect out of the z06 cam? i see you can find them relatively cheap on here..
also would i get any sort of power gains out of it if i just keep the stock converter? its going in my show truck which i wont be racing.. just a cruiser
Old Nov 7, 2008 | 11:14 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
No lope, should work great in a 4.8/5.3 with stock converter. Nice gains NA and even better mild FI.
Old Nov 7, 2008 | 11:22 AM
pewter00's Avatar
sweet man i appreciate it... now to the classifieds i go
Old Nov 7, 2008 | 11:33 AM
ZO6Ted's Avatar
Don't forget the springs.
Old Nov 7, 2008 | 11:36 AM
pewter00's Avatar
https://www.performancetrucks.net/fo...d.php?t=428136
i found that but someone is sayin it might not be a z06 cam? anyone have any truth? regardless its a good price if i'll get some power gains out of it right?
also where is the best place to get the pushrods and springs?
Old Nov 7, 2008 | 12:00 PM
chevrolet all the way's Avatar
it is a z06 just the older version not the newer... i can vouch since im sellin it lol. still will work good!
Old Nov 7, 2008 | 01:13 PM
pewter00's Avatar
whats the difference in the older version and newer version?
Old Nov 7, 2008 | 01:17 PM
95 bright teal's Avatar
Newer version is a little more aggresive
Old Nov 7, 2008 | 06:01 PM
Jessica's Avatar
Restricted User
01 = 204/211 .525/.525 116lsa
02-04 = 204/218 .551/.547 117.5lsa
The specs might seem small but the LSA and valve events make for the cams to be laggy in a truck compared to something that is correct
Last edited by Jessica; Nov 7, 2008 at 06:57 PM. Reason: Quoted Exhaust Centerline instead of LSA
Old Nov 7, 2008 | 06:47 PM
SynergyV8's Avatar
Originally Posted by Jessica
01 = 204/211 .525/.525 114lsa
02-04 = 204/218 .551/.547 115lsa
They might be real but they're definitely not the source of the brain material.
Let's get our numbers right.
01 204/211 .525 lift 116.5 LSA
02-04 204/218, .551"/.547", 117.5 LSA
