For you guys running 317's
I am doin a 5.3 s-10 build and have been researching this site and ls1tech heavily over the last few weeks and have changed my mind several times, I have pretty much settled on the 317 heads at this time because I have found some good deals on them. this is a budget 1/8th mile drag build that will have a cam and stall. Stock bottom end 5.3. My question is how much have you guys gotten away with milling these heads and running a good sized cam? I am thinking of going with the TR 220 cam??? Subject to change though. I have read over how to measure ptv several times but I just cant get it so Im hittin you guys up for any help, I really dont wanna flycut but if I have to do it to get a CR I will.
Any advice appreciated.
Do NOT use 317's on a 5.3 unless you are running boost over 15 psi. The compression will be around 8.5:1. Some 243's would be better if you shave them down. 243's and 317's are essentially the same head, just different size chambers. What cam are you thinking of?
317s are 72-74cc chambers
243s are 64cc chambers
317s have solid valves
243s have sodium-filled valves (if from a z06)
everything else is the same.
lxcoupe
Jul 21, 2015 02:12 AM
dantheman1540
Jul 18, 2015 01:13 PM
