wiseco pistons and ls1 heads?
Old Mar 5, 2009 | 11:17 PM
matty b's Avatar
Default wiseco pistons and ls1 heads?
hey, Ive been in the process over the last few months of getting parts together for my turbo 5.3. Wiseco recently came out with stock bore flat top pistons and according to their site with a 6.125 rod compression ratio is 10.4 with a 61cc chamber. If I were to bolt on a set of ls1 heads, would that be an acceptable way of getting the CR back down for turbo use or should I still consider spending a grand on custom slugs? I dont have any numbers on head gasket thickness cause thats still in the air as far as what Im gonna use but I think the stock MLS gasket is probably gonna be it. I guess on alot of numbers and came up with a CR of 9.3. If anyone can figure out the CR a little more exact than I can Id appreciate it or if anyone has any thoughts on going this route itd help me out a ton cause I know I can just trade my heads for some ls1 heads and be on my way, they get higher compression I get lower compression, win win.
Old Mar 5, 2009 | 11:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
243 castings (64cc) and flat top pistons will net 9.9:1 , why not look at a set of 317's?
Old Mar 5, 2009 | 11:28 PM
nonnieselman's Avatar
yea 317s have a 72? cc chamber..
Old Mar 6, 2009 | 12:49 AM
matty b's Avatar
Ill look at whatever gets me there the cheapest lol. Like I said I guessed on a few things calculating the CR and on ls1tech I found a table saying that stock ls1 heads were 66cc's (maybe I read it wrong) and I guessed on deck height. I was off by .6 but then again thats why I asked. Also the impression Im under is that these will match nicely with an ls6 mani right? I already have one so Im hoping thats the case. Any idea what CR Id end up with running these (cause its obvious I guessed wrong the first time). BTW Im shooting for 9:1 or within a tenth either way
Old Mar 6, 2009 | 10:30 AM
trever1t's Avatar
241 (ls1 heads) are not going to breath as well as the 243 (ls6/ls2) but the 317's will drop compression and breath as well as the 243's.
Old Mar 6, 2009 | 12:28 PM
matty b's Avatar
sounds good to me now I gotta find some. Anyone wanna trade lol
Old Mar 7, 2009 | 06:16 PM
Old Buzzard's Avatar
Lightbulb How about..
these??
https://www.performancetrucks.net/fo...d.php?t=436441
Old Mar 16, 2009 | 01:26 AM
matty b's Avatar
ehh those probably need to be surfaced and have a helicoil set in the head. Im low budget but not that low budget lol
Blue03sss
Mar 7, 2019 05:06 PM
axekick
Sep 7, 2015 07:01 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
NuckenFuts
Jul 9, 2015 08:45 AM
