Wiesco pistons arrow facing the wrong way?
Old Apr 10, 2012 | 09:06 AM
Q8 6.0's Avatar
Default Wiesco pistons arrow facing the wrong way?
I was going to install the pistons from the 408 rotating assembly I got from Texas speed then I noticed when I put the piston in the bore arrow to face the front of motor the two valve holes or dents or what ever they are called that are carved into the piston for valve clerence well they are on the other side closer to the exhaust side when the arrow is pointing to front? I am confused shouldn't they be closer to intake manifold??? If I did that then the arrow will point to rear of the motor.. Do you think I'm missing something here?
Old Apr 10, 2012 | 10:53 AM
oakley6575's Avatar
When I bought my rotating assembly from TS, they sent me pistons that were the exact same way. They said Wiseco just printing them backwards and that they were fine to use. Just make sure the valve cuts are lined up with the heads. My 408 hasn't had any problems.
Old Apr 10, 2012 | 10:54 AM
nonnieselman's Avatar
just check PtV clearance before buttoning everything up..
Old Apr 10, 2012 | 02:52 PM
Q8 6.0's Avatar
Wow so ts knew about this and didnt check to see if others are same that sux. I just hope no one gets anymore of these.
so should I install them upside down arrows pointing to rear of motor wouldn't that make the exhaust and intake valve on Opposit sides
Old Apr 10, 2012 | 03:11 PM
oakley6575's Avatar
Your just going to have to look at the underside of the head ans make sure the valve cuts are correct. Just put one piston in the hole and hold the head over the block. It was damn confusing at first when I was putting my short block together. I'm pretty sure the fwd sign was upside down and pointed in the wrong direction.
Old Apr 10, 2012 | 03:28 PM
Atomic's Avatar
I have a gauge for that
This is how LME assembled my shortblock with weisco pistons. The serial number is upside down but the forward marker is facing forward....the larger valve relief matches up with the intake valve...
Old Apr 10, 2012 | 03:59 PM
Q8 6.0's Avatar
My pistons look lil different here is a pic you can see when arrow is pointing to front of motor the valve Clarence dents are in the lower half of piston
Old Apr 10, 2012 | 04:12 PM
skeet's Avatar
same pistons i use in my 408
heres a pic that might help you out !
the small dome on the piston is the exhaust side ! if you need anymore pics just ask, i think i have a few more of them
Old Apr 10, 2012 | 04:27 PM
Q8 6.0's Avatar
Oh waw I was looking for a pic like that all day thanks Alot Skeet...so finally it looks like I should have no problem just installing them arrow facing other way thanks Alot guy
Old Apr 10, 2012 | 05:27 PM
oakley6575's Avatar
The intake valve is always going to be on the left. And the cuts will be on the top half of the piston. So half of your pistons will have the arrow pointing towards the intake valve, and other half towards the exhaust valve. But both should be towards the front of the motor.
