wich cam for a lq9 in a s10?
Old Feb 24, 2007 | 04:35 PM
ls1blazer's Avatar
Default wich cam for a lq9 in a s10?
with a ls6 intake
Old Feb 24, 2007 | 05:16 PM
joshluther's Avatar
T-rex
We need more info weight, gears, tranny, etc.
Old Feb 24, 2007 | 05:30 PM
02sierraz71_5.3's Avatar
whats the rest of the setup?
Old Feb 24, 2007 | 06:58 PM
ls1blazer's Avatar
oh.... 3200stall and 3.42 gears with shorty headers.Would it be worth milling the heads .30 ?
Old Feb 25, 2007 | 11:39 AM
onebadrubi's Avatar
Yes mill the heads would help with low end. Some 3.73 or 4.10 in that light of a truck would also be good. And allow more cam.
Im thinkin Magic stick 3. BUT YOU NEED Long tube headers.
Old Feb 25, 2007 | 01:13 PM
Stoichiometric's Avatar
I would do something like a 224/228 115, .570" with 918s .600" with dual springs. I personally would under-cam a truck for drivability, but for big power you need a big cam.
Old Feb 25, 2007 | 02:04 PM
onebadrubi's Avatar
I was asuming this wasnt a DD. if it is I would start considering like what Stoichiometric said.
Old Feb 25, 2007 | 09:45 PM
ls1blazer's Avatar
It's not a DD, I want the most bang for the buck with stock 317 heads and ls6 intake. I had a 224/228 114 lsa in a ls1 s10 previous to this one (it ran 7.84 in the 1/8). I was thinking of a 228/232 112 lsa since the 6.0 has a few more cubes. I would'nt want to go over .600 lift. I Wonder if it would out perform the ls1. This one will have the same 3200 stall. I have heard that the 6.0 is very de-tuned.That there is 60+ hp to be gained from just a tune. If thats true, then there should be problem out performing the ls1 I had. I worder what the rwhp would be ? close to 400?
Old Feb 25, 2007 | 11:43 PM
onebadrubi's Avatar
Why not go over .600 lift? I say run a good dual spring, PRC or Patroit Extreme. Then go with MS3 or something in the low 230's with XFI or LSK lobes.
Old Feb 26, 2007 | 09:10 AM
bluecajun5.3's Avatar
11 Second Truck Club
f13 or torquer v2
