Where can I find this cam
Old Apr 22, 2006 | 12:56 AM
jephs422's Avatar
Default Where can I find this cam
I've looked around a bit and I'm having ahard time find this grind. 215or216/224-116or118 and about .550ish. I know it's a bit vague, but I'm wondering if I'm going to have to have a custom grind, or if I can find something like that off the shelf. Any tips would be greatly appreciated.
Old Apr 22, 2006 | 01:37 AM
moregrip's Avatar
what a rush!
where are you getting these specs from?
Old Apr 22, 2006 | 01:46 AM
moregrip's Avatar
what a rush!
Comp XE lobe 3711 216 .561
Comp XE lobe 3715 224 .568
on whatever LSA you wish
Old Apr 22, 2006 | 01:48 AM
jephs422's Avatar
Dutweiller. He's building my 6.0 and has decided he wants to go with something like this.
Old Apr 22, 2006 | 01:49 AM
jephs422's Avatar
awesome thanks.
Old Apr 22, 2006 | 01:51 AM
moregrip's Avatar
what a rush!
I like this one as well:
ISKY CAMS
grind no type rr-257/275 hydraulic roller application excellent performance cam with good vacuum, good idle. 3.08 3.73 axle ratio. 9.5:1 compr. stock converter rpm range 1400-5600
valve lift int. ex. .510 .530
duration int. ex. 257° 265°
.050 duration int. ex. 212° 220°
lobe center 113°
Old Apr 22, 2006 | 01:52 AM
moregrip's Avatar
what a rush!
my personal favorite for a Blown Radix 6.0L is a Comp XER 220/230 on a 115
Old Apr 22, 2006 | 01:57 AM
jephs422's Avatar
keep in mind, I'm in the dark a little when it comes to cams. But, Dutweiller is going to be setting up my 6.o with 11:1 pistons on a 64cc chamber. I'm using 317 heads, so he's gonna mill them down to get me back to 11:1. He said he wants this cam spec to "bleed" the compressoin back down.
(of course, this won't be using a MP112)
Old Apr 22, 2006 | 01:58 AM
moregrip's Avatar
what a rush!
sounds like ls2 specs
nice PM me with the details
Old Apr 22, 2006 | 02:01 AM
jephs422's Avatar
Bingo....
