What's this noise??? (video inside)
Old Oct 1, 2013 | 08:01 PM
black00chev's Avatar
Slowest turbo build ever!
Default What's this noise??? (video inside)
https://www.youtube.com/watch?v=lEN8-By0V9s
Sounds like I have a lifter that is leaking down once warmed up after driving. This is what it sounded like after 30min of driving, took about 20min before it started, and took about 5min to get as loud as it is in the video. Just had cam swap done. Everything in the heads are new except valves and rocker arms, cam and lifters are also new. Lifters were even inspected but still make this noise. The shop doing everything is ordering new lifters tomorrow.
Old Oct 1, 2013 | 10:38 PM
AUTOT3K's Avatar
that definitely sounds like a failed lifter
what is that howling / chirping noise at the beginning of the video?
you should make a longer clip, move around the engine bay a bit and even increase the rpm's a touch. cause in this clip by the time everything quiets down and you can focus on the ticking...its over
Old Oct 2, 2013 | 05:36 AM
Yea my phone doesn't pick up audio the greatest. The sound you hear at the beginning is my alternator whistling.
Old Oct 2, 2013 | 10:26 AM
907rs's Avatar
Did your mechanic have the pickup tube off when this work was completed?
Old Oct 3, 2013 | 08:02 AM
AUTOT3K's Avatar
Or put on the wrong o ring
Old Oct 3, 2013 | 08:09 AM
AUTOT3K's Avatar
https://www.youtube.com/watch?v=pVWR...e_gdata_player I had a similar issue. It was the wrong o ring on the oil tube
Old Oct 3, 2013 | 08:52 AM
907rs's Avatar
My thoughts exactly. #7 and #5 lifters are the first ones to receive oil and won't pump up properly with air mixed in. I'd get a small flat tipped bar, slide it between the valve stem and rocker tip of both #5 and #7 cylinders and pry up.
If you're sucking air thru the o ring on the pickup tube, # 5 and 7 will bleed off rapidly when applying pressure compAred to the others. Another thing to note, oil pressure doesn't drop as much as you'd think when your o ring isn't sealed.
It may save you from pulling the heads only to find your lifters are not at fault.
Old Oct 3, 2013 | 09:27 AM
AUTOT3K's Avatar
I had fairly low pressure. Especially when rpms went up the pressure would drop right off to about 20psi
Old Oct 5, 2013 | 09:42 PM
They got the heads off on Thursday and found a collapsed lifter. Ordered new lifters and should be rocking by Wednesday.
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
carid
Oct 1, 2015 09:22 AM
