Whats the deal???
Old Jul 17, 2006 | 06:52 PM
One_Slow4.8's Avatar
Default Whats the deal???
why does everyone want to swap the ls6 intake on there 6.0l when it is a 5.7l and the ls2 is a 6.0???? this just came to me about 5 mins ago so if im completly wrong set me straight...
Old Jul 18, 2006 | 12:38 AM
they are all the same based engine, they swap out the intake manifolds expecting that the LS6 intake will flow much better in the higher rpms. the lm7 manifolds starts crapping out right before 6k so many swap intakes and im pretty sure the same is true about the 6.0 but not near as bad. i cant remember but i think the flow is pretty near the same for the LS6 and LQ4 but people want better flow up top for their high revving cams
Old Jul 18, 2006 | 07:03 PM
ok igot the reason why they swap intakes, but just not the reasoning behind using a ls6 instead of an ls2 intake. one would think that the ls2 would be a simple swap. ya know the same size motor the same bolt holes and stuff like that but idk.. no clue... just thinking.....
Old Jul 18, 2006 | 07:09 PM
nightrunner's Avatar
Mr. Obvious
when you swap to an ls6 intake manifold - car intake manifold, the front accessories are what has to be adapted to
Old Jul 19, 2006 | 12:12 AM
exactly, the water neck must be bent and brackets must be changed not to mention changes to fuel rails and stuff if it needs to be clean looking
Old Jul 19, 2006 | 07:30 AM
TURBHOE's Avatar
the ls6 has better flow numbers than the ls2 there are a couple threads on it. the guys that have gone with the ls6 have got good benefits from down low all the way up top. and all the truck manifolds are the same and yeah the crap out in upper rpm and after so many hp the kinda limmit air flow on n/a applications that is. boosted, well just look at parish.
jscherbs
Mar 24, 2017 07:20 PM
vmaxpro
Sep 28, 2015 11:10 AM
Big_pimie
Sep 22, 2015 09:07 PM
03chevytruck
Sep 14, 2015 09:15 PM
