What would be the benefit???
Old Jul 22, 2007 | 09:26 PM
Default What would be the benefit???
I bought a 67 swb chevy that I am using for my daily driver and I have a 4.8 and 4l60e from a 99. I was going to turn this into a iron block ls1 and I have a crank from a 5.3 and pistons from a ls1. What would be the benefit of just putting the 5.3 crank in and leaving the 4.8 rods and pistons or will that even work? I would like to build a 6.0 in place of the 4.8 for the original project that I was going to use the 4.8 for so it will be sitting there and I could use the mpg in the 67 truck. Should I just stick the stock motor in there and be done with it? Thanks to all.
Old Jul 22, 2007 | 09:49 PM
southern_chevy's Avatar
Not completely sure but I think that the 4.8 rods are to long. As far as the iron block 5.7l goes you can use stock internals to keep the price down and have a reliable motor.
Old Jul 22, 2007 | 10:58 PM
53bowtie's Avatar
the 4.8 has longer connecting rods like stated above coupled with the 5.3 crank which is made for shorter connecting rods and i would imagine you might have some piston to valve clearance issues....
Old Jul 23, 2007 | 01:21 PM
Probably leave it stock and stick a cam in it. How big a stall would I need for a 220?
Old Jul 23, 2007 | 02:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
in a truck of that era a 3000 stall would be nice!!! if you wanted to play a little harder move up to a 3200 or 3400 IMO... I DD a 3600 in a much heavier truck with no problems.
FlowmasterMufflers
Nov 24, 2015 01:00 PM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
FlowmasterMufflers
Aug 28, 2015 10:58 AM
