What would be the benefit???
I bought a 67 swb chevy that I am using for my daily driver and I have a 4.8 and 4l60e from a 99. I was going to turn this into a iron block ls1 and I have a crank from a 5.3 and pistons from a ls1. What would be the benefit of just putting the 5.3 crank in and leaving the 4.8 rods and pistons or will that even work? I would like to build a 6.0 in place of the 4.8 for the original project that I was going to use the 4.8 for so it will be sitting there and I could use the mpg in the 67 truck. Should I just stick the stock motor in there and be done with it? Thanks to all.
the 4.8 has longer connecting rods like stated above coupled with the 5.3 crank which is made for shorter connecting rods and i would imagine you might have some piston to valve clearance issues....
FlowmasterMufflers
Nov 24, 2015 01:00 PM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
FlowmasterMufflers
Aug 28, 2015 10:58 AM
