what pistons came in the 06 vettes?
Old Mar 8, 2010 | 08:03 PM
dry_kill's Avatar
Default what pistons came in the 06 vettes?
got a guy selling some pistons from a 2006 vette with low mileage, my question is what pistons are these? LS2/LQ9 pistons? If i were to put them in a iron 63.0 block, would that make the engine a LQ9? thanks fellas
Old Mar 9, 2010 | 07:52 PM
dry_kill's Avatar
anybody?
Old Mar 9, 2010 | 08:23 PM
1Bear's Avatar
The pistons, as long as they are from the base model LS2 and not the ZO6 are just 4" bore hypereutectic flat-top's. The use of them in a LQ4 would give you the same compression as a LQ9, because as you surmised the LQ9/LS2 uses the same pistons. You would need the matching set of floating pin rods to go with the pistons though.
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
