what intake with turbo/408 combo
Somewhere in the 700's depending on the dyno/drivetrain.I think the compressor just dosent flow enough up high.Now if you use a small cam with no overlap that would help.I think that would be a waste of ci. though.Then again I am not clear on your goal here.
This. Going to a bigger turbine house will just change where the boost starts (and changes the exhaust pressure), but you'll still be running out of breath up top.
From: Where our street cars are faster than your racecars..Mississippi
i'm not trying to have a 3800stall or it falling off at 5000rpm ether
i am willing to buy a 1.15ar (its divided) if it will "help"
i have a 2000 RCSB full size w/ manual windows/locks i am pulling the 4.3L out and swapping
05 wiring harness and computer (6.0l/4l80e)
05 avalanche front end
05 interior
i know i will want more but i'm sure it will be easier to build the motor nig now and swap out turbo's later rather than build a forged 370 and want more cubes later
05 interior
As I said in your other thread, that turbo will take you to 700ish, but no farther. Changing the exhaust housing won't change that.
