what intake with turbo/408 combo
Old Sep 12, 2009 | 09:15 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Default what intake with turbo/408 combo
i am going to be running 15psi maybe a lil more...
i am building a 408 with stock 317 heads what would be a good intake for this setup??
Old Sep 12, 2009 | 09:18 PM
Daryn's Avatar
Formerly darynC-10/23/10
if it would be my motor. i would probly run a victor junior and a elbow.
Old Sep 12, 2009 | 09:21 PM
what is that intake good for (rpm)
i was told my turbo should be real good from around 2000-6500rpm its a turbonetics T78mm w/.96ar upgraded to a 4" exhaust flange
JakeBrakeIH's Avatar
Im planning on running a vic jr on my 408...Im on the fence about running a elbow with a throttle body or a 4 barrel carb set up like thunder550 and dirtrackracer....
Old Sep 12, 2009 | 10:44 PM
broke1's Avatar
Banned
Stock truck intake with its big plenum volume is nice for forced induction...
Old Sep 12, 2009 | 11:25 PM
SincalT/A's Avatar
Take your pick the restriction will be in the turbo.What are your power level goals?
Old Sep 13, 2009 | 02:05 AM
Spoolin's Avatar
GFYS and STFU
Edelbrock XT PRO FLO...
Old Sep 13, 2009 | 10:06 AM
what do you think is capable???
Old Sep 13, 2009 | 11:47 AM
SincalT/A's Avatar
PT-88FTW
The 78 will get you 15psi but I have a feeling it will peeter out jus past 5000 rpm.
Old Sep 13, 2009 | 12:10 PM
PT-88FTW
what if i swapped it to a bigger AR like 1.05 or whatever turbonetics are??
i want it to be able to pull to 6000-6300rpm
and i will have 9.4:1cr so 15psi is fine with me
what do you think the rwhp will be around???
