What heads for an lq4?
yea i havent gotten the cam because im waiting till i get the heads and then get a custom grind for the heads but not sure which ones to go with so some 243 fully ported would be a good option how much of a mill would be good?
Give Richard @ WCCH a call he will direct you in the right direction
http://www.proheads.com/ He is a awesome guy to deal with.
If your on a budget you cant beat the 243's. There are better aftermarket heads but your looking at $1500-$2000. A set of 243's will give you about a 10.8:1 compression stock or you could mill .030 or so to get you into the low 11's on compression.
