What gaskets needed for cam swap?
Old 07-30-2012, 12:10 AM
iamkeniff's Avatar
That tensioner is for the newer blocks, your motor doesnt have a tensioner.
Old 07-30-2012, 01:13 PM
tqcraver00's Avatar
so should would a brand new gen3 timing chain work just fine?
Old 07-30-2012, 01:22 PM
AndysC3's Avatar
the Ls2 Timing chain will work. You just wont need the tensioner.
Old 07-30-2012, 01:45 PM
iamkeniff's Avatar
New chain is wise. A new oil pump is smart at that mileage while you have it apart (dod pump from a 07+ truck will work just fine) new oil pump o ring.
So the list is:
Cam
LS2 timing chain
Timing cover seal
Front seal (for crank pulley)
2 good water pump gaskets
LS7 lifters and trays
New pushrods spec'd out for cam/lifter swap/head gasket change
Head gaskets
Valve springs
Cam
Head bolts (i like arp head bolts bc of the ease of just torquing them in 3 sets vs wondering if you degreed the factory bolts correct or not)
Everything i do is pretty much over kill, the reason i say new oil pump and arp everything
Old 01-22-2024, 12:42 AM
Registered User
javiortiz's Avatar
Default Can swap and lifters
I’m trying to swap my cam out for a chopacabra cam and I wanna swap my lifters as well since I belive I have a lifter tic I was wondering what lifters should I get and what all gaskets should I get aswell I have a 2006 silverado 5.3
Old 01-22-2024, 12:47 PM
shakenfake's Avatar
Received 1,186 Likes on 903 Posts
@javiortiz You probably do not have lifter tick. However doing a cam swap you should probably swap the lifters.
Start a new thread of your own.
ZONES89RS
21
09-24-2015 05:58 PM
lo&sloSierra
08-30-2015 02:36 AM
Atomic
07-11-2015 03:51 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: What gaskets needed for cam swap?
