What gaskets needed for cam swap?
New chain is wise. A new oil pump is smart at that mileage while you have it apart (dod pump from a 07+ truck will work just fine) new oil pump o ring.
So the list is:
Cam
LS2 timing chain
Timing cover seal
Front seal (for crank pulley)
2 good water pump gaskets
LS7 lifters and trays
New pushrods spec'd out for cam/lifter swap/head gasket change
Head gaskets
Valve springs
Cam
Head bolts (i like arp head bolts bc of the ease of just torquing them in 3 sets vs wondering if you degreed the factory bolts correct or not)
Everything i do is pretty much over kill, the reason i say new oil pump and arp everything
So the list is:
Cam
LS2 timing chain
Timing cover seal
Head gaskets
Valve springs
Cam
Can swap and lifters
I’m trying to swap my cam out for a chopacabra cam and I wanna swap my lifters as well since I belive I have a lifter tic I was wondering what lifters should I get and what all gaskets should I get aswell I have a 2006 silverado 5.3
@javiortiz You probably do not have lifter tick. However doing a cam swap you should probably swap the lifters.
Start a new thread of your own.
