What gaskets needed for cam swap?
Old Jul 26, 2012 | 02:35 PM
tqcraver00's Avatar
Default What gaskets needed for cam swap?
I just got my ultra torque cam for vinci this morning
Been buying everything in pieces
Just have lifters and gaskets to buy
Is there a "cheaper" better route than the ls7 lifters?
I plan on getting cometic gaskets .04 thickness give me roughly .25 jump in compression. What is yall's opinion on this?
What other gaskets are a must?
Old Jul 26, 2012 | 02:47 PM
AndysC3's Avatar
How many miles on the engine? You dont have to remove the heads for a cam swap. Im still running the stock lifters. For gaskets:
water pumpx2, timing cover, timing cover seal, new crank bolt,
for heads, head gaskets, and new gm bolts.
I would look into getting the ls2 timing chain. cheap and alot stronger than stock
bottom is LS2
Old Jul 27, 2012 | 04:17 PM
tqcraver00's Avatar
150,000 miles so lifters are a must! If I go with the ls2 timing chain are you saying I have to get a new timing cover along with he gasket/seals for the timing cover?
Old Jul 27, 2012 | 04:49 PM
ak2007r6's Avatar
Just had this done to mine recently.
LS2 Chain
LS2 Cover
Old Jul 29, 2012 | 12:05 AM
AndysC3's Avatar
I resued my stock cam gear. Works fine. Ive spun mine to 6900 a few times and its holding strong. may also want to inspect the oil pump while your there.
Old Jul 29, 2012 | 12:58 AM
Ferocity02's Avatar
Any more info on that black plastic piece in the middle of the chain?
Old Jul 29, 2012 | 01:20 AM
Chevy_King1500's Avatar
I reused every gasket when I did my cam swap, if you cam is mild I would let the lifters alone. With the ls7 lifters you will need different length push rods than stock. Unless you are spinning it to the moon, a cam swap can be done pretty cheap, I spent no more than $400 dollars on mine
Old Jul 29, 2012 | 01:23 AM
Looks like a stock Ls2 timing chain dampener
Old Jul 29, 2012 | 03:22 AM
iamkeniff's Avatar
First if all some info on what year the truck is would be awsome
If it is a gen 3 motor your do not change the front cover nor does the LS2 wedge get used for you.
Gen 4 block there is a whole part list i did in the GMT900 section that breaks everything down to you.
Old Jul 29, 2012 | 11:31 PM
tqcraver00's Avatar
2000 5.3L
I believe gen 3
go in depth why the ls2 wont work
