what exactally do i need?
ok, so i want to put a cam in my truck, i was looking at the comp cams XFI RPM 220 224 .530 .534 112° so what all would i need with that cam?
here is a link to all specs
http://www.compcams.com/Cam_Specs/Ca...csid=1087&sb=2
You can pick both of those up from any local parts store, they're usually in stock or readily available.
Just the gaskets, not the whole parts. They are fragile and are not reuseable, although you could risk it if you are really cheap. Texas speed and performance sells a simple swap kit with the gaskets and bolt included.
lol i didn't see gaskets after that so is that cam really good up to 68000 rpm's? also how would i install one of these rpm gauges?
one more thing, does any one have part numbers?
http://prosportgauges.com/blue-tachometer-52mm.aspx
what is REQUIRED is some LS6 valve springs and a retune. along with the gaskets and fluids
some additional parts that you can add and are easy to go ahead and add now are
pushrods
timing chain
oil pump
better roller rockers
lifters, if you are going to pull the heads, you dont have to, btw
that cam might pull to 6800 rpms but sure wont go to 68000
hook the tach up to a 12v source, ground out to frame, and the signal wire can hook into the tach signal wire coming out the back of the cluster.
on the tach signal wire, i just searched to be sure and everything i can find says the white wire, but i could have sworn i hooked mine into the purple wire, but its been so long i cant remember
pushrods
timing chain
oil pump
