what do i look for in a cam?
Old 03-29-2009, 12:17 PM
Michael Halo's Avatar
Question what do i look for in a cam?
well guys as you know i have that lq9 that i'm going to swap in my 05.
my goal is a 400rwhp 12sec truck that i can drive daily so my Q is about cams
what do i look for in a cam high lift an a 112 to 14lsa? also i was thinking of going with a 3000 to 3200 stall and longtube headers and a Custom tune with a pulley...i don't know if they make a 90mm tb with drive by wire? so what cam do you guys think whould make me happy
Old 03-29-2009, 12:36 PM
yes on the 90mm tb but you need to find a tbss intake.
Old 03-29-2009, 01:04 PM
Hunt&Fisherator
silver-mod-o's Avatar
look for something in the high 220's low 230s duration for your 6L and a 110-112 LSA, depending on your power adder situation.
who will be doing your tuning???
Old 03-29-2009, 01:14 PM
GMCtrk's Avatar
tr224 is probably the most proven cam out there....check out some of Derek@EDO's old posts....I think his was TR224 LQ4 and SS3600 stall going 12.30s.
Old 03-29-2009, 01:42 PM
not sure whos best IYO?
Old 03-29-2009, 05:22 PM
low2001gmc's Avatar
i am in the process of acheving the same goal as you except i got an lq4. i looked at and emailed derek. after some more research i ended up going with a tr224/563/112 cam. i will also be running a vig 3200 stall and 3.73s. as for bolt-ons, march ud pulley, 8.1 injectors, jantzer ported tb on truck intake (truck intake better than ls2), pacesetter long tubes, ls1 fans. as for tuning, i believe derek used nelson performance. fastest truck i saw with that cam was tuned by nelson and ran 12.3s. just thought i share...
Old 03-29-2009, 07:46 PM
wow 12.3s thats fast what did it have?
Old 03-29-2009, 08:17 PM
some ls2's have a ls6 style intake which doesnt flow as good as the truck intake but the tbss ,ssr and nnbs truck have a different intake and flow better past 5500 rpm. Which would be better suited for a cammed 6.0 no matter what people say it helped my truck out alot . I would probably try to find a tsp 228r or somewhere around that if you are trying to reach the 400 hp mark.
Old 03-29-2009, 09:38 PM
what about the tsp 228/228 cam or should i look for a cam thats has something like a 228/230? and will the nnbs intake an tb fit?
Old 03-30-2009, 08:04 AM
any help guys???
Quick Reply: what do i look for in a cam?
