What Causes this Piston Damage?
Old Apr 7, 2010 | 01:03 AM
  #31
CODE4LS1's Avatar
Yeah that too.......screwed that post up. I also threw a rod on cylinder #11.
Old Apr 7, 2010 | 01:17 AM
  #32
AKlowriderZ71's Avatar
11 Second Hall Moniter
Okie Dokie Smokie.............lolz
Old Apr 7, 2010 | 08:57 AM
  #33
Denali08's Avatar
Checked the heads and found two bent valves on cylinder# 7!
Old Apr 7, 2010 | 02:52 PM
  #34
TurboGibbs's Avatar
That could have happened from the fragments getting caught in the seat.
Old Apr 8, 2010 | 02:07 AM
  #35
Denali08's Avatar
Originally Posted by CharlyNali6.2
damn sorry to hear this bro, hope u get it figured out.. your truck is one of a kind
Thanx bro. It will get fixed soon.
Old Apr 8, 2010 | 02:31 AM
  #36
stock48's Avatar
9 Second Truck Club
Looks to me like someone tried to play "King Of The Highway" on shitty gas. The rings definatly butted but most likely caused from detonation, and or it leaned out. You need to pull out the other pistons, and check the gap. That will tell you whose fault it is....
Old Apr 8, 2010 | 08:18 AM
  #37
Denali08's Avatar
I also thought the driver might used the cheap gas, although he was told not. He also stepped on it for sure.
I learned a hard lesson, never let someone else drive your modified ride.
I doubt it is ring gap. I bought the short block from a good engine builder and it ran perfect for more than 6-months with me stepping on it and driving offroad even during hot summer days with no issues.
It might be in the tune or failed fuel pump or injectors. I will pull the tune file and post it later.
Old Apr 8, 2010 | 08:34 AM
  #38
TurboGibbs's Avatar
My father in law bought a new vette in 07. He was complaining about the price of 93 octane. Knowing how he is, I told him very boldly to not put anything less than 91 in it. Well then next time I saw him he says, "man that thing don't like cheap gas!" "It was bucking and knocking"....ect. Some people just don't understand.
Old Apr 8, 2010 | 09:54 AM
  #39
Hawk179's Avatar
Look, we can all think all the things we want in this case. What you have to do is look at all the things that can happen. Here is what I would check for.
#1: Check to see how much oil was in the intake runners and in the manifold itself. You could of been detonating more and more over time because of oil in the air charge.
#2: Now that you have it apart, check the ring gaps on the other rings. This will confirm your gap theory.
#3: Send your injectors out and have them checked. Doesn't hurt to do a cleaning and check them at the same time.
#4: Your tune dont matter at this point, its already broken. Each engine combination is different, so unless we see something like 28-34 degrees of timing under the WOT area, I wouldnt start blaming it just yet. And 12.8 AFR is just a number. Like the others said here, the plugs tell the whole story. Some motors love 13.0 AFR, some love 12.2, its all just what it wants.
check these simple things and it should get your somewhere. Maybe someone else can add to my list, but it is early right now and thats all I could muster.
Rick
Old Apr 8, 2010 | 10:17 AM
  #40
TurboGibbs's Avatar
Rick
As you said, every engine is different. Mine likes 31* total timing @ wot and 93 octane.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
