What Can Go Wrong Will Go Wrong!!
#21
Wait, so this is an Avalance? that has the long 1 piece aluminum driveshaft? If so, that had to be your U-joints right since the factory driveshaft is rated mush higher, right? https://www.performancetrucks.net/fo...d.php?t=401966
#22
#23
#24
I was thinking about this, has anyone else read/thought that greasable Ujoints would be weaker than the non greasable because they have a hole drilled into them. I put greasable on mine as well but am wondering if it woudn't be better to go with non greasables next time.
#25
You'll never see a real race driveshaft with grease fittings.
#26
Don't know if they are hardened or not but hardening something does not really make it stronger, more wear resistant but also more brittle.
I saw an article about the ring and pinion gears used in top fuelers and they keep the gears soft and use different steel to begin with , the hardened gears were shattering under the huge HP levels!!
#27
Well turns out the rr end is shot too! Maybe that was the reason the works went boom
...So now I need to decide on what to do with the rr? Get a new/refurbished OEM, or go aftermarket? Any recommendations that won't cost me $2k wud be much appreciated!
#29
IF you have a factory locker... G80s are known to Suck.. I would advice a Detroit True Trac Nice HD unit Nothing to wear out.. Nothing to brake... I would think you could buy everything and have it installed in the 1000-1100.00 range..
#30
We think it was a combination of 20* of overlap on the old cam, plus the fact the rings were washed. 13lbs of boost on that didn't help either. We now have the same results on only 6lbs. IATs were no higher than 94* after 3 pulls on this set up...thats helped by the Alky 100% meth too! This cam has 0 overlap and the motor pulls way better up top, whereas the old set up rolled over @ 5000rpm. R/
Edit- I think I found your old cam specs 214/218 .559/.562 @ 114lc however do you mean 114lc or LSA? Whats in it now? I cant see the old cam causing the IAT's to be so high. Also at 6lb your IAT would be considerably less then at 13lb. Just brainstorming here....
