What cam to go with
Well i just got the mod bug and im starting out with a set of Stainless works long tubes with their no cat y pipe and a magna flow race muffler, shift kit for the 4l60e also a cold air... but now for the main qustion. im wanting to put a cam in it before i put the headers on and go get it tuned but not sure what one to go with.. i was thinkn a stock zo6 cam but not sure what year and if that would be enuff for what im planing on doing in the future with planes are runing a trubo any insit on this would help... or to just go with a bigger cam and then just change it out when i go and get my trubo thanks... o ya its a 5.3
The zo6 cam is a good choice, if you don't want to spend alot of money, works well for a turbo set up.. If I had to do it again, I would pick your FI cam, run it till you go FI.. It is too much to change it(cam) out just to slap a turbo on when the time comes, JMO. Do you ant to add a stall, gears ext.. That has alot to do based on your cam choice. I would look to upgrade the trans, rear, they will leave on ya first
John
John
If your gonna buy a cam get it for the time being. Dont put a z06 cam in planning on boost IMO. Just in case you never get it boosted. Another note is realize the z06 is popular because of the price. Better gains can be made with bigger cams. I DO run the 02 z06 cam....
woah i replied to this exact thread in gm engine/exhaust and i said exactly...
02 up z06 cam would be good and its good for forced induction already. you would hve to get a set of ls6 springs (usually about $50 to your door).
be sure to use the search. many people have done that and its worked great. just look around and you will find some good stuff!
welcome to your future debt!
Want to sell em
John
lawhitediamante
Aug 12, 2015 12:14 PM
