What Cam do I have. how to read it.
Old Feb 11, 2013 | 07:00 PM
shawnss's Avatar
Default What Cam do I have. how to read it.
Ok so this might seem strange to most. but Im not sure how to read this cam card I have. I had this cam spec'd about a year and a half ago. I had it done for a build I was going to do. but some things came up and I never got around to doing the build. I have sense changed my plans and am thinking of getting rid of it but not knowing what I have isn't going to help sell it. so i was wondering if somebody would be able to help me find out what cam I have.
I had this cam spec'd for a turbo 370 build I was going to do. I wasn't looking for a sleeper cam. I wanted a little bit a lope. a bit choppy but not to much so this is what was spec'd for me.
Heres some pictures of what card I got with it.
Old Feb 11, 2013 | 07:04 PM
03sierraslt's Avatar
218/218 .570/.570 112LSA +2 Advance Advertised lift with 1.7 rockers
In a 6.0 it is not going to lope, it will idle very smooth. It would be barely noticeable at idle, only to a trained ear.
Old Feb 11, 2013 | 07:09 PM
shawnss's Avatar
ok wow that was crazy fast. THANK YOU!!!!!!! thats what I was told by a local guy it was but I wanted to confirm it before trying to sell if off and give somebody the wrong information.
Old Feb 11, 2013 | 07:14 PM
I am not up to speed on what lobes Isky uses as I believe they have their own lobe, but based on those .006 specs it appears to be a less aggressive lobe so it should make for a quiet valvetrain. At a low enough idle speed it may be slightly noticeable depending on the exhaust after the turbo.
Old Feb 11, 2013 | 07:19 PM
shawnss's Avatar
Ok thanks you. Ill be sending it down the road. Its not going to work for the new build. so would it be good for a stock 6.0 or 370? Im going 400+ ci so I know it wont work for that. So thats the reasoning for wanting to move it.
Old Feb 11, 2013 | 07:38 PM
Ya, I would think it should work very well. Allot of guys are making good power on smaller cams with turbo's. I personally don't feel that you need a huge cam to make good power, there are allot of smaller cams with FI making great power across the board.
Old Feb 11, 2013 | 07:53 PM
shawnss's Avatar
Ok thank you. I know big choppy cams aren't good for the best for boost. but Im kind of wanting that sounds healthy. planning a 408 still planning on running the turbo with it.
Old Feb 11, 2013 | 08:11 PM
gamble686's Avatar
That is a great turbo cam, but not for a 400+ motor. This is perfect for stock cube LS motors 4.8/5.3/5.7/6.0 when used with a turbo. I would say go bigger for sure. Lots of 5.3 guys having success with the isk triple 112 and 118 but same goes for speed inc TU1 cams which are 225/225 .581/.581 LSA 113 it all depends on what you want. Also idle lope will depend greatly on the tune as well.
For a 400ish I would suggest the speed inc TU2 cam 236/236
Old Feb 11, 2013 | 09:26 PM
shawnss's Avatar
Its funny you say this because right now I have the TU2 cam in my shopping cart on speedinc just wanted to make sure it will work first.
fastjweb
Aug 15, 2015 10:47 AM
steves86ta
Jul 28, 2015 10:21 AM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
