what amount of hp can a stock l92 bottom end handle?
Old Apr 13, 2011 | 04:45 PM
willysl92's Avatar
Default what amount of hp can a stock l92 bottom end handle?
ive acquired a blown l92 engine, dropped a valve in cyl 5 and then sent pieces through intake and destroyed both cyl 5 and 7 pistons and connecting rods, the sleeves are clean, no gouges, had them checked, crank is also clean, originally wanted to stroke to a 416, but i have the chance to get two new stock connecting rods and would only have to get two pistons to reassemble the engine
using ported heads, bigger cam, not sure how big, depends on what i do with the bottom end, but im curious as to how much the stock bottom end will handle or if id be better off going with a forged bottom end,
shooting for the 600-650 hm range
thanks for any help
jake
Old Apr 13, 2011 | 05:50 PM
Swerve7rpm2000's Avatar
5,000,000,000,000,000,000,000,000,000,00 Nueclear Atoms to the balsamic muffler bearing in ordinance of the efficiency of Gear/Tire Ratio being monitored
Old Apr 13, 2011 | 05:58 PM
viciousknid's Avatar
Where's the Beef?
pretty much any lsx motor can handle 1000hp with stock bottom end but I'd put some ARP rod bolts in if you plan to run in the 600's
Old Apr 13, 2011 | 09:24 PM
some have put down 1,600, the new stock cranks are a nice piece compared to old school 350 motors, ive researched it before and ive seen people running anywhere from 800-1000 hp but you probably want a good tune
Old Apr 14, 2011 | 09:24 AM
willysl92's Avatar
thanks for the info guys, i think ill go with the stock bottom end and use the arp bolts
thanks again
Old Apr 14, 2011 | 07:14 PM
Daryn's Avatar
Formerly darynC-10/23/10
i made 655 before broke #7 ring land
Silveradorst07
Dec 31, 2015 12:04 AM
thunder550
Oct 8, 2015 04:53 PM
fcompean
Jul 15, 2015 09:55 PM
kdw8888
Jul 9, 2015 10:52 PM
