What aftermarket heads
Old Oct 20, 2013 | 12:40 PM
GREENSIERRA's Avatar
Default What aftermarket heads
So I pulled my 799 heads to do lifters and while I was at it I was gonna mill them .30, valve work and P&P them. The guy doing them checked them and found 3 cracks on 1 and 4 on the other so now I guess I need new heads.
What is a good aftermarket head for my combo that will work but not get me divorced?
Thanks, Mitch
Old Oct 20, 2013 | 12:42 PM
Whitecrewcab's Avatar
They are aluminum, why not just weld them up and have them machined, probably still be cheaper than aftermarket heads.
Old Oct 20, 2013 | 12:47 PM
They already have that many cracks now it won't stop as I keep adding power so may aswell upgrade while they are off
Thanks, Mitch
Old Oct 20, 2013 | 01:29 PM
Noah Burns's Avatar
your sig says you already have P&P heads... so why would you be doing more p&p work on already p&p'd heads?
haven't heard of many LS motors cracking heads on NA applications especially at the power levels these truck motors are at NA, that's pretty strange.
Just get a new set of stock heads and start over. I've got a set of 5.3s in the garage I'll sell ya.
Old Oct 20, 2013 | 01:31 PM
GMCSIERRA5.3's Avatar
PRC heads are somewhat budget friendly
Old Oct 20, 2013 | 01:45 PM
I put P&P heads cause they were getting done but now this happened I have to change my plans
Been thinking of PRC 2.5
Old Oct 20, 2013 | 01:51 PM
terravast4's Avatar
the PRC heads are great
Old Oct 20, 2013 | 03:03 PM
craigsix's Avatar
check with scoggindickie also.
Old Oct 20, 2013 | 05:59 PM
WICKEDOWESIX's Avatar
Prc 243/799 heads
Old Oct 20, 2013 | 06:37 PM
Originally Posted by WICKEDOWESIX
Prc 243/799 heads
What kind of gains would I get over the 5.3 heads?
Is it worth the extra couple hundred?
I have a brand new rec port intake kicking around, worth switching to rec port?
