what 2 bore a lq4 to
Old Apr 13, 2011 | 09:32 PM
04herod's Avatar
Default what 2 bore a lq4 to
ok i got a stock lq4. but i got a p1 prochager for it so i was goin 2 put all arp bolts and studs and new bearings and a cam swap. so i figured mite as well put new rings n it also. and one thing 2 another. if i am goin that far mite as well just bore it and put a good boost/nitrous piston n it. so my question is how much do i bore it and what size piston would i need. thanx
Old Apr 13, 2011 | 09:36 PM
Mangled03gmc's Avatar
Baltimore Whore
If the bores look good, you could leave it, just do a frged stock cube set up. Or you could go 30 over and get 370 out of it... Once you go big on a bore, if something were to happen , you need a bore to clean a hole up, if it is 40-60 over you will not have enough to take out if the wall is scored bad enough.. Plus when you bore a block over 60+ you run the issue of problems, because the walls get then.. Not so much a issue on NA set ups but more so when you boosting them..
Old Apr 13, 2011 | 09:55 PM
04herod's Avatar
so i could do 30 over and get a good piston and b good 2 go or would u say just get a good piston and leave it. it runs fine and has nothing wrong with it just want 2 runn alot of boost.lol
Old Apr 13, 2011 | 10:05 PM
black04's Avatar
hone it out to 4.005
Baltimore Whore
However you want to do it, either stock bore or 30 over.. Stock cubes are 364, 30 over would put you at 370.. So not much diff there.. How much boost you looking to run??
Old Apr 13, 2011 | 10:06 PM
Swerve7rpm2000's Avatar
If u dont have to bore it dont! No reason to, you will see no difference and if you have problems in the future you have more cylinder walls to work with
Old Apr 14, 2011 | 12:01 AM
04herod's Avatar
i would like to run prolly 16 mite have 2 upgarde to a d1 or sumthing but i want 2 b able 2 go as mush as i can with the p1. and not have 2 worry bout the pistons and rings. which i kno the tune will have part n that also
Old Apr 14, 2011 | 12:06 AM
stock48's Avatar
9 Second Truck Club
x2! The only reason I went .030'' on my 370 is the block had a nick in one cyl and I couldn't get .020'' pistons at the time.
Old Apr 14, 2011 | 12:09 AM
04herod's Avatar
4.005 would change the ci to what or would it even?
Old Apr 14, 2011 | 12:14 AM
Baltimore Whore
No that is basically a clean up..
