Welp it happened - 427ci lq9 ate it
Old 04-27-2017, 10:25 AM
  #21
darkirish63's Avatar
Yeah - I'll double check mind but I'm pretty sure this was my issue -
Attached Thumbnails Welp it happened - 427ci lq9 ate it-20170406_124213.jpg   Welp it happened - 427ci lq9 ate it-20170406_153133.jpg   Welp it happened - 427ci lq9 ate it-20170406_153240.jpg
Old 04-27-2017, 10:32 AM
  #22
03sierraslt's Avatar
What lifters do you have now? Just curious what your running with that thick oil.
Old 04-27-2017, 10:36 AM
  #23
Was running LS7s in the old motor but will run Johnson 2110s in the new one. Ran the oil in my 383 Stroker on advise from the builder - too thick or ?
Old 04-27-2017, 11:12 AM
  #24
If you talk to Johnson they will advice against thick oil with their lifters. They weren't crazy about me running 10/40 for break in. Just an FYI
Old 04-27-2017, 11:34 AM
  #25
thewrx's Avatar
When mine had similiar symptoms was from trunion kit, but used stock bolts which bottom threaded hole out in the head thus not clamping rocker down tight enough. To naked eye everything looks kosher, and you can even get to tq to spec. Switched to comp bolts after fixed rocker worked like a champ (stock l92 except springs). Still ran a 12.0 on 7 cylindars in a tbss though. Sounded kind of like a misfire
Old 04-27-2017, 11:51 AM
  #26
What do you use, then?
Old 04-27-2017, 11:55 AM
  #27
I'll run 10/40 for initial break in the go to Gibbs BR30 till I hit 500 miles. I plan to run a 5/30 or 10/30 in it ultimately.
Old 04-27-2017, 01:14 PM
  #28
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
What lifters is the OP running?
This has me questioning the LS7s I have waiting for my 408
Old 04-27-2017, 07:05 PM
  #29
Spoke with Joe @ Johnson and he did indeed say 10W/40 at the heaviest. I'll probably run straight 30 VR1 after break in.
Old 04-27-2017, 07:48 PM
  #30
​​​​​​​Spoke with Joe @ Johnson and he did indeed saw 10W/40 at the heaviest. I'll probably run straight 30 VR1 after break in.
Yep, just a heads up for those reading this. I forget who I usually talk to. Very nice guy and informative, I called once for a simple question and 30m later I was better informed. Great customer service.
