Video on new LSX Block
Old Dec 25, 2006 | 09:16 AM
Originally Posted by TurboGibbs
Doesn't need sleves, it is cast iron. 4.250 bore X 4.500 stroke is 511ci.
I'd be happy with just a 4" or 4 1/8" bore, to leave somematerial to work with later. Anyone know how much a rotating assembly would be for that monster? It sure would be sweet to go mid quality and build a 500+ cid motor for under $6k.
Old Dec 25, 2006 | 10:17 AM
dirt track racer 81's Avatar
Originally Posted by PappyDan
ok so after march who is going to have a
twin turbo 511ci small block.
im sure every one is thinking parish
Old Dec 25, 2006 | 10:39 AM
Stoichiometric's Avatar
Can you run the block as cast? Or does it need an intial bore or hone before building? If you left the cylinders alone, you could build a 30+ psi 402 with the short deck version. I am sure you could get away with a lot of boost with a big overbore aswell, but it would be very stable with all the meat between the cylinders in stock form.
GM may need to offer a 4L80X transmission case, that thing is going to make some power.
Old Dec 25, 2006 | 10:41 AM
their building this big badass motor but why dont think build a big bad *** transmission to go with it?
Old Dec 31, 2006 | 11:03 AM
parish8's Avatar
single digit dreamer
if i do one of those i would go with a 402 or a 408 if i can reuse the pistons i have now. no need for all those cubes when you can just turn up the boost.
Old Jan 4, 2007 | 06:23 PM
meatwad's Avatar
Fast lane preferred
to that we all say this, why not do both.....though the turbo would have to be a fatty....
Old Jan 4, 2007 | 06:43 PM
parish8's Avatar
generaly when building a high boost motor you are more concerned with strength than anything else. thicker walls=stronger.
i think the monster cubes with mild boost for a pump gas friendly 1000+hp set up would be doable
Old Jan 4, 2007 | 07:35 PM
Bill Reid's Avatar
Super nice block... the thought process that went into that block for the modiholic, as discussed in the video, is overdue but VERY welcome none the less. The matching GM 6 bolt heads should be an awesome compliment.
Bill
Old Jan 4, 2007 | 09:34 PM
meatwad's Avatar
Fast lane preferred
You are definitely right, I guess with the amount of material they put into the cylinder walls there should be a happy medium between the bore and strength of the walls for boost to yield max power with a decent amount of reliability. In any case, I am looking forward to whatever anybody does with this thing. High boost, no boost, assloads of N20....whatever.
I am leaning towards a decent size N/A version for myself a couple years down the road.
drummer0415
11
Oct 24, 2015 08:16 PM
gmcyukon
Oct 5, 2015 06:20 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
USMCvet0311
Sep 4, 2015 09:43 PM
