valve springs
Old Nov 28, 2010 | 03:08 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by double047
Damn you guys are creative.
I wish that I could say that it was my idea, but it's just an old trick that I learned a long time ago...as mentioned, it works real well when you don't have access to shop air
Old Nov 28, 2010 | 11:19 AM
mr mississippi's Avatar
thanks for the help guys. cause i sure didn't want to take my heads off again
Old Nov 29, 2010 | 11:53 AM
Sales2@Texas-speed's Avatar
Former Vendor
We offer a tool that makes it simple!
http://www.texas-speed.com/shop/item...=1098&catid=48
That $14.99 tool listed at the bottom makes charging the cylinder with air to keep the valves up easy too!
Old Nov 29, 2010 | 05:53 PM
budhayes3's Avatar
PT's Slowest Truck
That is the best valve spring compressor there is, hands down Is that the Crane tool, or a variation of it? (looks just like it) I'll never do springs on an LS engine with any other tool again
Old Nov 29, 2010 | 06:00 PM
Atomic's Avatar
I have a gauge for that
I did it the exciting way and just hoped the valve seals held the valve long enough to get the spring installed
Old Nov 30, 2010 | 09:12 AM
Former Vendor
When Crane shut down we had this one made to fill that demand in the market. It is similar, but not the same tool.
Old Nov 30, 2010 | 11:34 AM
CashDudeHomie's Avatar
I just used the TDC method on my 6.0. They would only drop about an inch and the piston caught them. I used the metal tool that bolts into the rocker arm hole and pushes the spring down. Don't even think about using the cheapo twist on compressor tool.
Old Dec 3, 2010 | 11:01 PM
budhayes3's Avatar
PT's Slowest Truck
Very cool, that's a must have tool for a GM LS engine "enthusiast" for sure
Old Dec 30, 2010 | 05:01 PM
ok how do i keep the lifters from dropping in engine when i take cam out
Old Dec 30, 2010 | 05:28 PM
Former Vendor
When you remove the cam retainer plate, there are a couple oil galley holes through which you can slide 5/16" wooden dowels. With the rockers already off, start advancing the dowel in as you turn the camshaft over by hand (don't pull the cam out just yet). As the lifters hang in the trays, the dowels will put the extra pressure/friction on the bottom of them to keep them from coming down. Do that on both sides. Then you can pull the camshaft without having to worry so much about the lifters!
jtphelps289
Sep 29, 2015 12:00 PM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
LT-1 SS
Sep 3, 2015 10:24 AM
mr03silverado
Sep 2, 2015 11:43 PM
