Valve knock at start-up
Old Mar 6, 2007 | 05:24 PM
ramdaspadhye's Avatar
Default Valve knock at start-up
Hey guys. I know the 5.3's have a tendency to have that valve knock on cold startups, but how long should that last? It continues to knock on mine until I drive about 50 feet after I let it warm up for a minute or two, then it quits... It's only like 40 degrees here. Any ideas why it would be makin so much noise? Any way I can fix it?
Old Mar 6, 2007 | 05:35 PM
GMGen3's Avatar
It's actually piston slap, and they all do it (some worse than others). It's not worth worrying with. My old grocery getter could be mistaken for a Duramax first thing in the morning.....and it's 190K and still going strong.
Old Mar 6, 2007 | 05:51 PM
Well I don't effin like it! lol, it scares me sometimes it gets so loud...you can actually feel it. It goes away, though, and won't do it for the rest of the day. Just in the morning times....
BTW, this isn't on topic, but I was actually considering gettin rid of my 5.3 short block and swapping in the 6.0. How hard is that to do? Can I take everything off my 5.3 and put it on the 6.0? If so, that'd be great. Let me know!
Old Mar 6, 2007 | 08:18 PM
GMCHammer's Avatar
11 Second Club
Yes, but I would do a 6.0 and buy a nice set of ported heads if your going that far!
Old Mar 6, 2007 | 08:57 PM
365ZUM's Avatar
Just so you know, my 06' 6.0L does the same thing on a cold morning with only 10k miles!
Old Mar 7, 2007 | 09:29 PM
Stoichiometric's Avatar
My 2000 6.0L makes all kinds of noise in the morning. Pistion slap on accel and valvetrain noise upon decel. I put 15W40 Rotella T oil in it last change and that quiets it down. The truck has 130K miles still running strong.
Old Mar 7, 2007 | 09:32 PM
nonnieselman's Avatar
mine sounds like a old Powerstroke!!!! 155k miles and 5w-30 Mobil-1... Only on a 45 or colder morning... I let it warm up and stop knocking before i get in it or put it in gear.
Old Mar 7, 2007 | 10:20 PM
LS1TRUCKGUY's Avatar
i went with a little bit thinner oil this time around for winter, and mine knocks like the FBI on a crack house for about 1-2 minutes upon cold start up. its a lot quieter with some 15-40 oil in it.
Old Mar 7, 2007 | 10:27 PM
GMGen3's Avatar
Old Mar 7, 2007 | 11:10 PM
05RST2NV's Avatar
I think im having the same problems with my 5.7 LS1. You can only really hear it when the hood is up. Its not a knock just a light tap and it queits down after warm up. I been freaking out cause i got a dyno pull friday morning.. So i shouldn worry,,?
