Valve Clearance
Another way is to call a reptuable machine shop in your area and tell them what you are trying to accomplish (what parts you are adding, power, etc.) They should be able to give you the answer you are looking for.
Originally Posted by 1TRUESS
I am hearing .30" is the max to be safe with the lift that I am planing on running.
does anybody read what I type, I give up.
I guess I missed that, but i talked to Richard at WCCH and he was not sure but told me to watch because of the lift I am running.
You should be shooting for 11:1 to 11.5:1 SCR for that cam thats gonna work out to around .050 off depending on how much material is taken out of the CC if your going ported, the ls1 guys run truck heads with flat tops and .050 off and alot more aggressive cams, with a 5.3 youve got dished pistons to boot. Your no where near p/v.
.050 off a head makes a head thin
and you dont need that much off a head. to do it safer and cheaper get .030 off if you need that then get a .040 gasket. since you already need head gaskets why not get a thinner one instead of milling heads and running into intake alignment/sealing issues. also when you take a lot of the surface of the head you will also need to take material off the intake side
Right now I am just thinking I am going to mill the heads. No PP at this time. I am thinking I might get a spare set of 706 heads so i can do some math.
Edit after reading Quik's post:
So I guess I can save more money and just buy differant gaskkets to up my CR!?
