Uh oh, i dont know...........
Old May 18, 2011 | 09:14 PM
00buckshot's Avatar
Default Uh oh, i dont know...........
Ok guys, mods in sig, pulled my fast intake off the truck tonight to do a swap, got to lookin and the #2 intake port on the head is WAAAY cleaner than the other 7, I'm not sure if i had an injector problem or what, lookin for advice on this one, gonna do a compression test on it tommorow when i get off work. just hopin for the best as i only have around 3,000 miles on this motor................any insight?
Old May 19, 2011 | 07:04 AM
bigboy576103's Avatar
Damn that's strange usually one might be cleaner but its usually towards the bak. I'm interested to see what other say here. GL man
Old May 19, 2011 | 07:21 AM
budhayes3's Avatar
PT's Slowest Truck
Maybe that injector is sticking open and washing the cylinder down?
Old May 19, 2011 | 08:32 AM
00buckshot's Avatar
Thats what I'm stuck on, its either stuck open and washing it down, or not puttin any fuel out. The injectors are racetronixs 44# flow matched, have maybe 5,000 miles on em, hell i may have a bad connection, who knows..
Old May 19, 2011 | 08:56 AM
MikeGyver's Avatar
How does the #2 spark plug compare to the others?
Old May 19, 2011 | 09:04 AM
00buckshot's Avatar
Have not pulled it yet but last time i changed them before i hit the track it looked different than the rest, sorta brown lookin, what does that tell ya?
Old May 19, 2011 | 08:10 PM
MikeGyver's Avatar
That it is getting oil in the cylinder, or as you fear, too much fuel.
Old May 19, 2011 | 09:08 PM
00buckshot's Avatar
well, checked compression with the intake off, shot up to 225 relly fast, valves are good, pushrods, spark plug was brownish, i hooked injectors back upt and srun it and all spit fuel out just fine, im thinkin maybe a bad connection or i didnt plug it up real good on that injector
Old May 20, 2011 | 01:13 AM
Spoolin's Avatar
GFYS and STFU
If you had a bad connection the spark plug wouldn't be brown would it?
Old May 20, 2011 | 02:27 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Brown = too much fuel.
A fouled plug would be black or wet.
A poor electrical connection on the injector would cause the injector to not fire properly, which would result in a lean cylinder, and the plug would be white, not brown.
To the OP, I believe you may have an injector problem. If you don't want to send out the injectors until you know for sure, move that injector to a different cylinder and recheck it after you put some miles on it. Don't race it or beat on it until the problem is solved.
