Ugh another cam question... sorry.
Old Nov 14, 2011 | 05:12 PM
maxh's Avatar
Default Ugh another cam question... sorry.
Looks like the "what cam should i use?" question is a popular one. Sorry guys, I know nothing about engines and I need to ask it.
My truck threw some codes at me yesterday on a trip home so I had the shop look at it today (GM dealer I work at). Being told the cam is toast. I have been thinking of putting one in anyway so what better timing?
Heres the truck info. 2007 NNBS 5.3L with active fuel management. Crew cab 2wd. Zero engine/performance mods at this time. Used to tow on occasion. Daily driven to work and back (not too far) and mostly city driving. Of coarse I want something that will still tow and do the highway. Not overly concerned with fuel mileage. Future plans to add a converter and headers, but not right now. Understand I will need to tune right away.
So... What cam should I get?? Do lifters and such at the same time?
Old Nov 14, 2011 | 07:33 PM
AndysC3's Avatar
212/218 low lift will do what you need. If your cam is toast than the chances are your lifters are toast as well.
Old Nov 14, 2011 | 07:55 PM
Coban's Avatar
Can't really go wrong with this cam or the hi-lift version. I consider both "go-to" cams for someone in your situation. I had the hi-lift in my 5.3. It was a good performer with the stock stalled TC.
Don't make the mistake of letting someone talk you into a 220 range cam...
Old Nov 15, 2011 | 11:30 PM
Hemi2Slo's Avatar
12 Second Club
I just swapped from a 224/224 cam to a 210/220 custom grind. Coban is right, over 220 is too much for a 5.3. The 210/220 I just put is is pretty high lift at .596/.581, but I've got supporting mods and heads. I haven't had experience with the 212/218 cams but I am well pleased with the 210/220, it tows great and makes great power from idle up to about 6200. My old 224 cam didn't do jack below about 3300 rpms. It sucked for a truck.
Old Nov 15, 2011 | 11:47 PM
grey matter 04's Avatar
13 Second Truck Club
I agree 100% been there swapped that
Old Nov 16, 2011 | 02:53 AM
Amedee's Avatar
Do vinci "butt-kicker" at 210/218 .551 .551 112
Or vinci "asp-kicker" at 210/218 .551 .551 114
Or comps 212/218 "low lift" or "high lift"
All of these cams or great cam and none would dissapoint.
Old Nov 16, 2011 | 12:52 PM
dmelvin's Avatar
You'll need to get rid of your DOD lifters, so you might as well replace all of them with LS7 lifters.
As far as which cam, these guys have you on the right track.
Old Nov 17, 2011 | 03:05 PM
Lucille's Avatar
DOD lifters are most likely what toasted your cam in the first place.
Old Nov 19, 2011 | 08:43 AM
budhayes3's Avatar
PT's Slowest Truck
You have those LSA's swapped, the asp kicker is on a 112 and butt on a 114.
*EDIT* I said "butt"...
I can vouch that the asp kicker is great in a 2wd rcsb 5.3, with or without a converter. I drove tdrumm's truck many times in both configurations and it was stout
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
