Two Types of Valve Seals?
Old Mar 18, 2010 | 11:40 AM
Ferocity02's Avatar
I just ordered a Fel-Pro gasket set that comes with the "top-hat" style valve seals rather than the "positive seal" type. The part number is HS9292PT1. Looks like a pretty complete set for the top end and should be good for a daily driver rebuild.
Old Mar 18, 2010 | 01:00 PM
black04's Avatar
They changed the seals and seats to a 1 piece in 2001 i believe. 99-00 should have seperate seals and seats.
Old Mar 18, 2010 | 02:50 PM
Mrgoodwrench3's Avatar
GM part numbers for the valve seals I bought for my 07 LY5. Different for intake and exhaust. These have the shim built in as one piece.
12482062
12482063
Old Mar 18, 2010 | 03:15 PM
budhayes3's Avatar
PT's Slowest Truck
They're separate on my 99 5.3...not sure what WCCH installed on my 317's though...
Old Mar 20, 2010 | 09:13 PM
carolinaz71's Avatar
I just got my springs off and it has the 2 piece seals, I have the one piece since that is what it calls for via my vin #. Think it'll be fine installing the one piece? I took the first two seals off before I realized it, they seem to fit fine thou.
Old Mar 20, 2010 | 09:25 PM
GMCtrk's Avatar
Yes, install the 1 piece seals.
Old Mar 20, 2010 | 09:32 PM
Haha oh i already did, once i got the springs off i said i'll chance it. Gonna fire it up in the am!!!!
Old Mar 21, 2010 | 01:33 AM
Ferocity02's Avatar
I'm guessing you can go from a two-piece seal to a one-piece w/o buying any extra parts. But to go from a one-piece to a two-piece I'm guessing you would have to buy some stock spring seats, which are dirt cheap on LS1tech.
Old Mar 21, 2010 | 01:52 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Be sure to remove the shims(that used to be under the valve springs).
Old Mar 21, 2010 | 06:31 AM
I did remove the old seat, the new ones have the seat built in
