Tsp cams
Old Nov 28, 2010 | 12:39 PM
KozzyJr's Avatar
so with the 228 will a 3000 stall be enough, also i have 2 new auburn 3.73 gears just installed last week
Old Nov 28, 2010 | 01:26 PM
terravast4's Avatar
you will need at least a 3000 stall and 3.73's
Old Nov 28, 2010 | 03:22 PM
Jake99's Avatar
It will work but if it were me id go 10in 3200 for a daily, the gears are fine but i think you would like the 10in converter alot better with that cam.
Old Nov 28, 2010 | 10:56 PM
KozzyJr's Avatar
been doing some research and alot of ppl are loving there 228, would it be easier to get 375wrhp plus with the 228r or a torquer v2?
Old Nov 28, 2010 | 11:14 PM
06Sierra2's Avatar
id say contact patrick g. do a search. he will spec u a custom grind cam for cheap that will net u the most hp out of your cam. thats what im gonna do with my 6.0 build someday
Old Nov 28, 2010 | 11:24 PM
Jake99's Avatar
Peak power will be easer to make with the v2 cause its a bigger cam but the 228 with do better under the curve, if you go v2 with a 3600 to 4000 stall would be the setup i would go with, my cam is a 232 236 comp xer so its almost the same as a v2 and i have a 4000 stall and love it, its a perfect cam-stall combo for my ls1. chose what stall you want before your cam, a 6.0 can take alot more cam then just a v2 if your willing to put enuf stall in it. I say 228 with a 3600 or smaller and v2 with 3600 or bigger..
Old Nov 28, 2010 | 11:55 PM
06Sierra2's Avatar
i personally think you could dd a v2 with a 3400 and 4.10s in a 6.0
Old Nov 29, 2010 | 05:59 PM
Jake99's Avatar
I agree as far as it drives even a 3200 would work, i guess what i ment to say is as far as track times you need a 3600+ stall to make the v2 work real good. If its a bit lugish off the line and you pick up no et over what the 228 would then theres no need for the bigger cam unless you street race alot, i see the v2 doing better on the street.
Old Nov 29, 2010 | 08:45 PM
matt29201's Avatar
Originally Posted by blue4.8
I just put the tsp228 in my 5.3 and I love it and its my dd. Also running the stock converter for now. I raced a buddy and he has my old 220 and also a 150 shot and let's just say he didn't pull on me much. Won't ever go back to a smaller cam.
quit bragging! haha all jokes aside that 228 pulls good in a 5.3
i would go v2 and a 3600 with a 6.0. imo
Old Nov 30, 2010 | 05:21 AM
slowec's Avatar
I spent way more time on his tune tho, we need to dial urs in and rematch yall
