tow/performance cam L92 heads
Old Oct 5, 2012 | 11:57 AM
moregrip's Avatar
what a rush!
Default tow/performance cam L92 heads
What are your thoughts on a cam for a stock motor w/L92 heads in selecting a performance cam that can still tow the factory rated loads taking full advantage of the excellent flow at higher lift?
(data provided by WCCH)
4.030” test bore
LIFT___IN___EX
.100 _74.9. 63.6
.200_154.4 126.1
.300_225.3 162.3
.400_274.6 189.6
.500_308.8 205.5
.600_328.7 214.6
.650_326.6 217.8
The intake was tested with a radius plate and the exhaust was tested with a 2 ½” stub pipe.
Old Oct 5, 2012 | 03:14 PM
iamkeniff's Avatar
I personally like the square port trucker cam bc it works great with stock exhaust, gears, converter
Old Oct 5, 2012 | 06:50 PM
moregrip's Avatar
what a rush!
What are the specs on that?
Old Oct 5, 2012 | 08:00 PM
amanuel's Avatar
If your setup has vvt then it may be worthwhile to get a cam which utilizes it. It'll still give you a noticeable it'll grant you more torque and from my understanding, just overall better for towing.
Might wanna get an experts opinion though. I mentioned that simply because I know the L76 has l92s and it utilizes vvt in its stock form.
Old Oct 5, 2012 | 08:25 PM
03sierraslt's Avatar
Originally Posted by moregrip
what are the specs on that?
dur @ .004" 277*/ 289*
dur @ .050" 216*/ 228*
lift .585/.585
lsa 115*
Old Oct 6, 2012 | 02:35 AM
moregrip's Avatar
what a rush!
Nice!
Old Oct 6, 2012 | 07:19 AM
sand man's Avatar
lift .585/.585
lsa 115*
sounds friendly
Old Oct 11, 2012 | 12:34 PM
moregrip's Avatar
what a rush!
any other inputs over here?
Old Oct 11, 2012 | 03:37 PM
53bowtie's Avatar
What about a TRuTorq Thunder Racing cam? Maybe level 1 or 2? They have close to the same specs as the cam listed above but a little more lift to take advantage of those heads.
TR TRuTorq" Level 1 - 219/224 .609/.604 115 LSA
TR TRuTorq" Level 2 - 223/230 .609/.604 115 LSA
Old Oct 12, 2012 | 08:45 PM
moregrip's Avatar
what a rush!
can you tow with those buggers at the factory rated levels?
