torquer v2?
Old Sep 8, 2008 | 09:41 PM
la blue's Avatar
Default torquer v2?
how many of you have used the torquer v2 cam and did you guys liked how it perform.
Old Sep 8, 2008 | 09:50 PM
dirt track racer 81's Avatar
whats it goin in? most truck guys stay with 22x dur cams..but with the right bolts ons im sure it would scream
Old Sep 9, 2008 | 12:00 AM
la blue's Avatar
its going on a 2003 rcsb 6.0 lq4 with ported ls2 heads fully bolt on ,3600 pi,411 gears.right now i have a 228 228 588 588 on a 114 lsa truck runs good but i would like to go a little bit bigger like the torquer v2 on a 112.so what do you guys think.
7845's Avatar
Banned
http://videos.streetfire.net/video/Q...tion_47438.htm video of Torquer. search this user and youll see his truck in action and specs on it
Old Sep 9, 2008 | 06:46 AM
99Silverado5.3's Avatar
Throw it in there..should run very well with ported heads...I would even look at the v3 if I were you. Either cam should scream.
What intake you running?
Old Sep 9, 2008 | 12:46 PM
rgvsierra's Avatar
ayt, you konw how mine worked. just get it 112+ 0.
Old Sep 9, 2008 | 01:14 PM
sickREDsierra's Avatar
unless its a white extended cab, then you can run 24x duration.
have you put up an idle vid of your cam? i am seriously dying to hear it.
Old Sep 9, 2008 | 09:03 PM
Originally Posted by sickREDsierra
unless its a white extended cab, then you can run 244/248 duration.
yep click the link. the afr in this was 11:1 and i got it up to 13:1 now and sounds a lot different..i need to get that on here some day https://www.performancetrucks.net/fo...ight=244%2F248
Old Sep 13, 2008 | 04:23 PM
I'm putting a V2 in my 5.3
Old Sep 16, 2008 | 04:32 PM
Sales2@Texas-speed's Avatar
Former Vendor
I'm partial to the V3 personally over the V2. That aggressive intake lobe on that camshaft helps it make a bit better power under the curve from all we've seen in testing! if you've got a 228R and want more, either will make you happy though!
Let me know if I can help with anything
Marcello7x
Feb 15, 2011 07:02 PM
miller white
Sep 23, 2010 12:39 AM
griff04
Sep 1, 2009 10:39 PM
