Stock converter with LS1 and torquer 2 cam in CCSB?????
would this work at all? like i said it is a CCSB with LS1 and torquer 2 cam. i do use the truck to tow. if the stock converter wont work then what converter would you recommend going with?
you want to tow with that torquer 2?
that thing is going to have no low end. you'll need a stall of some sort to get it into the powerband. the problem with that is smaller diameter/higher stalls aren't ideal for towing. you will also need to get a big trans cooler if you plan on doing a lot of towing with it.
torquer 2 in a 5.7 ? . . . yea it'll work 232/234 .595 .598 -112
stock stall . . . sucks out of the hole . . . but a freeway missile - get a yank stall
idle - sounds good . . . that's about it
it'll work better with different heads
trans - short life, more heat, . . . heavy foot
if you dont drive it hard (assuming you dont plan to either) buy a smaller cam. Like a 212/216, I would MAYBE run that big of a cam in my 6.0 RCSB.
your set up is impractical all over the place. Re think the strategy buddy. Cut your factory stall maybe and get a baby cam like 212
GMCtrk
Jul 17, 2015 06:39 PM
