torque on mains
15lbft for inner and outer then inners to 80* outers to 51*. The torque angle meter is $10 at autozone. its very easy to use and yes you can reuse stock main bolts. the side bolts go to 18lbft and are recommended to be replaced, but its only because they come with sealant on them.
Main cap bolts are not TTY and can be reused. Head bolts and that crank pulley bolt you reused is TTY and needs replacement after uses.
hey tim wellington, if your in Wilson you only live about 30-40 mins away from me. Hope build is going good. You can re use the main cap bolts and the side main cap bolts. The side bolts do get a good thread sealant on them or they will seep alittle oil to the outside of the block
lukn4trbl355
Oct 21, 2015 11:19 PM
Cammed4ever
Sep 30, 2015 03:38 PM
