timing chain
Old Mar 2, 2011 | 09:34 AM
black4.8's Avatar
Default timing chain
whose still running stock chain? will be installing turbo kit soon, thinking about upgrading the sloppy stock chain. wish i did it w/cam install but i was too tight i guess. never heard of one breaking, just piece of mind. 55,000 miles and running very stiff patriot dual extreme valve springs. i crank on it pretty good (6800 redline).
Old Mar 2, 2011 | 09:42 AM
Gadgetized's Avatar
I upgraded my chain just for piece of mind. It wasn't any thicker, and just as sloppy. I was sort of disappointed by the new chain.
Old Mar 2, 2011 | 09:52 AM
JFOLM's Avatar
What chain did you go with Gadgetized?
Old Mar 2, 2011 | 10:46 AM
DBRODS's Avatar
Get the GM HD chain. It's a lot thicker than the stockers in the truck engines.
Old Mar 2, 2011 | 01:57 PM
budhayes3's Avatar
PT's Slowest Truck
I believe this is the chain that you're referring to, it used to be known as the LS2 timing chain, can't beat the price at just over 43 bux
http://sdparts.com/details/gm-factor...parts/12586482
A few guys have asked about the Iwis chain also, not sure of anybody using it, but it looks like a nice piece:
http://sdparts.com/details/scoggin-d...enter/sd3sr602
Old Mar 2, 2011 | 02:07 PM
06Sierra2's Avatar
didnt some years come with the ls2 chain stock? i swear when i did my cam swap i held my chain right nxt to a ls2 and it looked exactly the same
Old Mar 2, 2011 | 02:22 PM
TX Tahoe Z71's Avatar
I got the Iwis chain. Haven't swapped cams yet, but read about it over on Tech and a number of people seemed to prefer it over the LS2 because of the early LS2 chain failures. I'll see if I can dig up the thread.
Old Mar 2, 2011 | 02:38 PM
budhayes3's Avatar
PT's Slowest Truck
I think that around 05 or something the LS2 chain became standard equipment
I remember hearing something about that too, but haven't heard of any LS2 chain failures around here...
Old Mar 2, 2011 | 04:40 PM
Gadgetized's Avatar
I went with the LS2 chain. Here is what it was supposed to look like vs. and old chain.
Here is what it really looked like vs. the old chain.
I think that around 05 or something the LS2 chain became standard equipment.
My truck is an 05, maybe thats why. Either way, if i had the cover off I can't see being in there without changing it. I initially thought it would be thicker though.
Old Mar 2, 2011 | 04:53 PM
budhayes3's Avatar
PT's Slowest Truck
I remember noticing that my LS2 chain was meatier than my original, but I'm a 99...I'm sure that if we did a little research (or if Jarrod - 1Bear chimed in), that we'd find out that the LS2 chain did become standard equipment somewhere along the line, whether it be 04, 05 or whatever
