Time For a Bigger Bumpstick
Old Jan 24, 2008 | 09:41 AM
  #21
WJ MARK's Avatar
Originally Posted by ZZebes
I got the LS2 when my 5.3L decided that it wanted to end up in pieces. it is a 6000 mile GTO LS2. A Turbo is in the back of my mind but will stay there for the foreseable future
hows that ls2 compare to the 5.3?
Old Jan 24, 2008 | 10:12 AM
  #22
ZZebes's Avatar
It's just sick, the LS2 just loves to rev and is eager to get n go
it's being choked a little by the fact that i have stock LS1 heads and a Small cam, but that will be remedied in the next few weeks
Old Jan 24, 2008 | 11:12 AM
  #23
WJ MARK's Avatar
the number your putting down with the current setup or the old motor with juice? sorry for all the questions. Just sounds like a cool setup!
Old Jan 24, 2008 | 11:34 AM
  #24
ZZebes's Avatar
Those numbers are a stock 5.3L with Juice
I never dynoed the H/C 5.3 cause it wouldnt stay running right long enough
current numbers coming soon
Old Jan 24, 2008 | 03:18 PM
  #25
Tootall's Avatar
Originally Posted by DozerDan
looks real similar to dirt track racer81's nitrous cam...i bet yours is for a different purpose though
It's a MTI x1 cam. They're a local shop in Houston
maybe i haven't follow to close. When did you get the LS2? was it a new motor? are you planning on doing a turbo also
His 5.3 was breaking/melting the oiler rings, there were parts in the bottom. He was spraying a 150 shot on a stock bottom end . . - very often.
Originally Posted by nickpc82
Its gonna be badass. Congrats on the cam and motor, hopefully you have better luck with this motor.
It'll last if he doesn't spray this one too !
Old Jan 24, 2008 | 03:26 PM
  #26
joshua022's Avatar
Do you think it would be worth it to build a H/C 5.3 or should I go to a 6.0 and build it like your doing?
Old Jan 24, 2008 | 03:38 PM
  #27
ZZebes's Avatar
100% honestly i think that there is alot of very good performing 5.3L's out there that perform close to the 6.0 and get better gas mileage. if i had found another 5.3L i would have put it in, but i stumbled on this motor and figured i'd try it since i'd venture to say i'm one of less than a handful of LS2 GenIII's out there
If your 5.3L is running well than go for the H/C route and don't look back, i don't see the point in pulling a motor that runs well.
Old Jan 24, 2008 | 04:17 PM
  #28
joshua022's Avatar
I 'll start my own thread so I don't hijack yours.
Old Jan 24, 2008 | 09:03 PM
  #29
ZZebes's Avatar
Gettin Started on it here in the next few minutes.Idle clip sometime after midnight and a few pics if i get a chance
Old Jan 24, 2008 | 09:51 PM
  #30
Tootall's Avatar
yeah right . . .. who's over there doing the work for you
