Are these the pistons i need for my 5.3 to 5.7 build?
Old Feb 23, 2008 | 06:22 PM
chevyguy7802's Avatar
Default Are these the pistons i need for my 5.3 to 5.7 build?
Been looking at parts for my motor i found this Mahle forged pistons and ring set here are the details
LS1/LS6 Chevy PowerPak Piston Kit
Forged 4032 High Silicone Aluminum Alloy
Bore: 3.898''
Pin Diameter: .945''
-1cc Dome Volume
Compression Ratio @ 64cc: 10.7:1
Precision Ring Grooves for Included 1/16'', 1/16'', 3/16'' Rings
Stroke: 3.622
Rod Length: 6.622
Compression Height: 1.314
Weight: 398g
I plan on running 243 heads....just trying to figure out if these are the correct ones...any help would be greatly appreciated!
Old Feb 23, 2008 | 06:54 PM
Keith's Avatar
That rod length is not correct. Stock rod length would be 6.098" on all but the 4.8L and 7.0L engines. It looks to be that the .622 from the stroke got transposed to where the .098 should be.
Do you want your compression to be at 10.7:1?
Old Feb 23, 2008 | 07:00 PM
I was trying to find the stock rod length spec.....thanks for claryfying that!
Yea im wanting the compression around 10:5:1
Old Feb 23, 2008 | 07:30 PM
BlackGMC's Avatar
Resident Retard
Is there something wrong with the motor you bought or are you just improving it? There are the stock rod lengths..
Old Feb 23, 2008 | 07:58 PM
Dark Halo's Avatar
I am intrested as well, I am doing the same swap for my 92.
Old Feb 24, 2008 | 09:51 AM
Its pretty gummed up nothing was broke just the people didnt maintain it.....so im just gonna go ahead rebuild it
Old Feb 24, 2008 | 11:55 AM
Dark Halo's Avatar
how much boring is done to get to a 5.7 on a 5.3 block? How thin will the block be? And is it safe for everyday use?
Old Feb 24, 2008 | 12:14 PM
InchUp's Avatar
Look around the forums for "5.3 to 5.7" or similarly named threads. Your question has been covered a few times and the machine work has been done. Simple answer, you're going from a 96mm 5.3 bore to a 99mm 5.7 bore and then just use LS1/LS6 pistons.
Old Feb 24, 2008 | 01:02 PM
ForcedTQ's Avatar
From the above graph posted it's simple subtraction. (3.898-3.779) = .119 inches difference in bore diameter.
Old Feb 24, 2008 | 02:12 PM
Dark Halo's Avatar
yea I kinda fiqured that but I guess the question should have been re worded. I have only had sbc bored out and I was always told to keep it at .060 or less and on this block it will be .119 so I was really asking how safe is this for an everyday driver?
