thermostat question
Old Nov 1, 2013 | 10:22 AM
Bagman's Avatar
Default thermostat question
Got a quick question. I am running a 160 thermostat in my supercharged 5.3 airboat. The radiator sits about 7 inches away from my 80 inch diameter prop. On the water pump I have the 5/8 heater hose nipple capped and the 3/4 inch nipple has a 3/4 heater hose attached that goes above the motor to a resevoir where we remote fill etc. since the radiator is below the engine.
While cruising and running my engine temp stays dead nuts at 161. But when idleing for a while the temp will creep up to 200 or so usually I am back to getting on plane before it rises higher than 210. Doesnt overheat or anything like that and if I idle at say 1500 to 1700 rpms the coolant temp comes right down to 161. It doesnt appear to be a fan issue, since I have a huge prop pulling air through radiator.
It appears to be a flow issue when idleing at low rpms. You can feel the intake hose going to thermostat and it is significantly cooler than the output hose at idle.
What modifications can i do to the thermostat to let more flow at idle? Drill holes? BB mod?
Any thoughts or suggestions would be greatly appreciated.
andrewlong
Nov 9, 2016 09:38 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
