Is there a thicker HG than the stock 3 layer MLS?
Old Dec 5, 2008 | 08:51 AM
TXsilverado's Avatar
higher compression with a proper cam will get you low end.
higher compression without boost=good. as long as there's no P 2 V clearance issues. but if your set on lower compression i think cometic will make customized gaskets on request
Old Dec 5, 2008 | 09:08 AM
skyhighsami's Avatar
no title here
My engine builder just toid me about that possibly being an option earlier. So we are going to look at that when the motor goes together.
Old Dec 5, 2008 | 01:33 PM
no title here
Do the custom Cometics MLS gaskets have the same issues as the off the shelf ones? I have just read a lot of bad things about their gaskets and such.
Old Dec 5, 2008 | 02:28 PM
cometic makes one of the best gaskets out. what bad things have you heard?
just put a light coat of copper spray on them and bolt them down according to torque specs
Old Dec 5, 2008 | 03:43 PM
no title here
Search over on LS1Tech in the FI section
Old Dec 5, 2008 | 09:24 PM
zippy's Avatar
Check into the gaskets for the LS9. They may be more cc than the stock LQ4 one's. They are also a 5 layer.
Old Dec 5, 2008 | 09:31 PM
no title here
I spoke with the guy putting the machining the motor and all today and Cometic makes a .065, he said he has used them alot and has never had any trouble out of them. So it looks like I have found my solution. Using that gasket and having the pistons even with the deck I have reached my target CR of 10.9 so I am just going to run them provided the measurement on the piston is correct or close
chopperloco
Jul 10, 2016 10:45 PM
OLD BULL
Aug 1, 2015 05:00 PM
lxcoupe
Jul 30, 2015 02:42 PM
bbowerman
Jul 26, 2015 10:57 PM
Ketis
Jul 23, 2015 12:37 PM
