Texas Speed Gasket set
Old Dec 20, 2011 | 06:09 AM
06Sierra2's Avatar
Default Texas Speed Gasket set
I am looking to buy the texas speed gasket set listed in the truck section on TSP's website. However, for the kit i only see the LS1 bore mentioned. What about the stock 3.78 5.3 bore? My plans are to go with a .40 or .45 cometic gasket and ARP head bolts. I am still undecided as to whether i will swap the oil pump, timing chain/gears so that is why i want the whole gasket set, that way i have it just in case, or if i decide to do it later down the road. i have already purchased ls7 lifters and ls2 trays. All of this is going on my truck when i get back from deployment next month so i would like to buy myself some xmas presents now.
I am planning on purchasing the prc 2.5 heads as well. i just want to get all the accesories bought first. i know this has been talked about before. I did search, however, i found more threads about boring the cylinders than similar setups so i decided to start a new thread. Thoughts on the head gasket and overall setup would be greatly appreciated, thank you.
5.3 crew cab sierra:
78xxx miles
224 cam, 3200 stall tc, 4.10 gears
daily driven, 22 inch rims
tuned, full exhaust
Old Dec 20, 2011 | 08:19 AM
dmelvin's Avatar
When I ordered from them, I got their cam gasket kit, which has water pump gaskets, crank bolt, and maybe a few other things, can't really remember right now. I ordered the head gaskets seperate. I used .040 cometics, but it was for the 3.901 bore because of my 243 heads. Cometic makes a .040, and .045 gasket for the 3.78 bore, you'll just have to call TSP and ask for it.
Old Dec 20, 2011 | 10:43 PM
terravast4's Avatar
Just call them up. I got a set for my 05' 5.3. Tell them what you need and they will hook you up.
Old Dec 21, 2011 | 01:41 AM
06Sierra2's Avatar
alright, calling them is kinda hard overseas but im gonna try and pm matt from tsp i guess. or maybe one of their sponsors will see this and comment. any other thoughts on changing the oil pump? it sounds like a PITA and i would like to just leave it alone since i dont have any pressure issues but it would suck to throw on a new topend and have issues down the road. I was looking at the Melling pump. thoughts?
Old Dec 21, 2011 | 08:34 AM
dmelvin's Avatar
TSP will recommend one, I didn't get one just because I didn't want to do the work to put it in, I was already going to have my DD down for a couple days and didn't want to add to that. My stock oil pump is still strong @ 164k
Old Dec 21, 2011 | 11:00 PM
06Sierra2's Avatar
yeah, i know what u mean on that. i dont really feel like putting that work in either, and since im eventually planning on a 6.0 ill prolly leave it as is. thanks for the input
edit: i sent a pm to matt at texas speed, thanks.
rednekferlife101
32
Jan 8, 2016 10:42 PM
thewrx
Aug 12, 2015 08:28 PM
Sales4@Texas-Speed
Aug 3, 2015 03:57 PM
Sexyrado327
Aug 2, 2015 04:08 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
