telling a lq4 from a 1q9
Old Feb 2, 2009 | 11:45 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default telling a lq4 from a 1q9
whats the best way to tell them apart without pulling off the heads im going to look at one just want to be sure its a lq9 and not a lq4
Old Feb 3, 2009 | 12:00 AM
LQ9 should be drive by wire. I'm pretty sure my dad's 99 with LQ4 is cable actuated. Lemme go check.
Old Feb 3, 2009 | 12:17 AM
all the 03 ups had the dbw 99 to 02 had cable
Old Feb 3, 2009 | 01:04 AM
LowBlack99's Avatar
Head casting #??
Old Feb 3, 2009 | 02:40 AM
Originally Posted by LowBlack99
Head casting #??
so what are the casting numbers on a lq9 i think there 317s
Old Feb 3, 2009 | 03:08 AM
charcold-bowtie's Avatar
pretty sure this has been asked. Look at the pistons... bore scope
Old Feb 3, 2009 | 03:14 AM
viciousknid's Avatar
Where's the Beef?
A Lot.
We should add some kind of search feature.
Really It took me 30-40 seconds to go to the Gm engine section click Search this forum. Type lq9 lq4 hit search and find the following thread.
https://www.performancetrucks.net/fo...hlight=lq9+lq4
Sarcasm of course. Letting you see how I found it helps others see how they too can find things.
Old Feb 3, 2009 | 03:46 AM
GMCtrk's Avatar
Nope, 02 lq9 had the vette DBW.
You can limit it down pretty easily by checking if there is a spacer at end of the crank. This will be an LQ4. If there's no spacer, that narrows it down to either an LQ9 or an LQ4 out of a denali. Given that probability, and being told it was an lq9, I would be assured it indeed was an lq9.
Old Feb 3, 2009 | 05:51 AM
Mangled03gmc's Avatar
Baltimore Whore
The spacer was only on the 6.0 with the iron heads on it(99-early 00), once they got aluminum heads, they went with the shorter crank.. Pull a plug out and check the pistons, theres not a truly easy way to tell, unless you seen what it actually came out of..
Old Feb 3, 2009 | 07:26 AM
ap2002's Avatar
only way to tell is to look at the pistons
LQ9 = flat top piston
LQ4 = dished piston
