<TECH ONLY> Lifter Preload
#31
PT's Slowest Truck
So ideally you'd want to order different length pushrods for each valve, if the difference warranted that, correct? Can you order pushrods 1, 2, 4, or 8 at a time? I really get where you are going with this, if you don't have adjustable rockers to compensate, you can't get proper preload.
#33
Rick
#34
I do agree however, with the newer lifters you need to check and make sure you are using the right length rods. I found this out the hard way on a motor I built last year. The valvetrain noise was very loud and for the life of me I couldnt figure out what was going on, since I built the standard setup. LQ4 shortblock with a set of stage II 243s, patriot springs and 7.4 rods. Turns out the owner gave me a set of caddy lifters to put in the motor(they were just in a bag not marked), once I found that out and searching on tech turns out I needed a 7.35 rods and all the sudden the motor was much quieter.
You've got a pretty big range to play with on preload anyway, and if youre not quite in the perfect range and on the loose side you can make up for it with a heavier weight oil to keep the lifter pumped up a bit more to help with excess valvetrain noise.
Im currently building another LQ4, Im wondering if I should spend the money for some caddy lifters or just roll with the stockers(no idea what year so Ill have to check prod length). The caddy lifters are quite a bit lighter than the stockers, but then again Im not going to be spinning this thing more than 6K anyway.
#36
PT's Slowest Truck
Roger: "Do you need pushrods?"
Me: "Yes, but I don't know what size yet as I will be measuring when I put the engine together"
Roger: "OK, that's good...what lifters are you using...you're not using the Caddy lifters are you?"
Me: "No, I will be using the stock replacement LS7 style lifters"
Roger: "Good, I've seen too many problems and failures with the Caddy lifters"
Me: "****, there's my boss....sorry gotta go Roger...I'll be back in touch"
So that's as much info as I was able to get due to the circumstance, but I trust Roger Vinci as he has always been straight up with me in the past, and I have ordered parts and tools from him more than once through the years. You can take it for what it's worth, I'm sure that there's a lot more info on Tech about the Caddy lifters...
#37
Hadnt heard that, but I pretty much answered my question as I typed. There really is no need for me to upgrade, im just going to disassemble my current lifters and make sure they're in good shape.
#38
FYI, just built another run of the mill LQ4 yesterday and ended up needing 7.35 PRs. Thats with the new style lifters, .051 headgasket, gt2-3 cam(smaller base circle) and .04 preload. Im on the light side but Ill make up for it with a little heavier weight oil, I like the heavier oil for the bearings anyway so it works out
I used regular cheapo fel pro gaskets, Im interested to see if they hold up as well as the regular GM MLS that Ive always used if I didnt use a cometic or titan gasket.
#39
PT's Slowest Truck
Here's a good tech article about lifter preload from Crane Cams: http://cranecams.com/?show=techarticle&id=2
#40
Rick
